Domain Engineering with Event-B: Some Lessons We Learned - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Atif Mashkoor
  • Fonction : Auteur
  • PersonId : 854132
Jean-Pierre Jacquot
  • Fonction : Auteur
  • PersonId : 830614
Domain modeling is an important aspect of software engineering. This paper presents our experience of modeling land transportation domain in the formal framework of Event-B. The domain exhibits interesting features, such as high levels of non-determinism, complex interactions, stringent safety properties, etc.. Time is an essential multifaceted feature of the domain. We discuss the problems posed by the introduction of time and some of the solutions we developed. Assessing the validity of a model is also a complex task. We designed a technique based on animation which can help this activity.
main.pdf (223.12 Ko) Télécharger le fichier
inria-00431133 , version 1 (10-11-2009)
inria-00431133 , version 2 (19-10-2010)
  • HAL Id : inria-00431133 , version 1
Atif Mashkoor, Jean-Pierre Jacquot. Domain Engineering with Event-B: Some Lessons We Learned. [Research Report] 2009. ⟨inria-00431133v1⟩
70 Consultations
338 Téléchargements
