Lower Bounds for Pinning Lines by Balls (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
It is known that if n>=2d pairwise disjoint balls in R^d have a unique line ℓ intersecting them in a given order <, one can always remove a ball so that ℓ remains the only line intersecting the balls in the order induced by <. We show that the constant 2d is best possible, in any dimension, and derive lower bounds on Helly numbers for sets of line transversals to disjoint balls in arbitrary dimension.
Pinning-Eurocomb09.pdf (83.92 Ko) Télécharger le fichier
inria-00431437 , version 1 (12-11-2009)
Otfried Cheong, Xavier Goaoc, Andreas Holmsen. Lower Bounds for Pinning Lines by Balls (Extended Abstract). European Conference on Combinatorics, Graph Theory and Applications - EuroComb 2009, Sep 2009, Bordeaux, France. pp.567-571, ⟨10.1016/j.endm.2009.07.094⟩. ⟨inria-00431437⟩
81 Consultations
133 Téléchargements
