Lower Bounds for Pinning Lines by Balls (Extended Abstract)
It is known that if n>=2d pairwise disjoint balls in R^d have a unique line ℓ intersecting them in a given order <, one can always remove a ball so that ℓ remains the only line intersecting the balls in the order induced by <. We show that the constant 2d is best possible, in any dimension, and derive lower bounds on Helly numbers for sets of line transversals to disjoint balls in arbitrary dimension.
Géométrie algorithmique [cs.CG]
