Service curves in Network Calculus: dos and don'ts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This report is a survey about service curves used in envelope-based models for worst-case performance evaluation, like Network Calculus or Real-Time Calculus. In a first part, we compare different models and their notions of service curves by establishing a hierarchy and similarities between different types of service curves and in a second part, we compare the behaviours of simple and strict service curves for concatenation and residual service curves.
RR-7094.pdf (363.23 Ko) Télécharger le fichier
inria-00431674 , version 1 (12-11-2009)
  • HAL Id : inria-00431674 , version 1
Anne Bouillard, Laurent Jouhet, Eric Thierry. Service curves in Network Calculus: dos and don'ts. [Research Report] RR-7094, INRIA. 2009, pp.24. ⟨inria-00431674⟩
854 Consultations
2000 Téléchargements
