Universal Sets of n Points for One-bend Drawings of Planar Graphs with n Vertices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2010
This paper shows that any planar graph with $n$ vertices can be point-set embedded with at most one bend per edge on a universal set of n points in the plane. An implication of this result is that any number of planar graphs admit a simultaneous embedding without mapping with at most one bend per edge.
universal-revised.pdf (139 Ko) Télécharger le fichier
2010 Universal Sets for One-bend Drawings.png (19.41 Ko) Télécharger le fichier
Format : Figure, Image
inria-00431769 , version 1 (13-11-2009)
Hazel Everett, Sylvain Lazard, Giuseppe Liotta, Steve Wismath. Universal Sets of n Points for One-bend Drawings of Planar Graphs with n Vertices. Discrete and Computational Geometry, 2010, 43 (2), pp.272-288. ⟨10.1007/s00454-009-9149-3⟩. ⟨inria-00431769⟩
306 Consultations
280 Téléchargements
