Logoot: A Scalable Optimistic Replication Algorithm for Collaborative Editing on P2P Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Stéphane Weiss
  • Fonction : Auteur
  • PersonId : 839033
Pascal Urso
  • Fonction : Auteur
  • PersonId : 830668
Pascal Molli
Massive collaborative editing becomes a reality through leading projects such as Wikipedia. This massive collaboration is currently supported with a costly central service. In order to avoid such costs, we aim to provide a peer-to- peer collaborative editing system. Existing approaches to build distributed collaborative editing systems either do not scale in terms of number of users or in terms of number of edits. We present the Logoot approach that scales in these both dimensions while ensuring causality, consistency and intention preservation criteria. We evaluate the Logoot approach and compare it to others using a corpus of all the edits applied on a set of the most edited and the biggest pages of Wikipedia.
main.pdf (144 Ko) Télécharger le fichier
inria-00432368 , version 1 (16-11-2009)
Stéphane Weiss, Pascal Urso, Pascal Molli. Logoot: A Scalable Optimistic Replication Algorithm for Collaborative Editing on P2P Networks. 29th IEEE International Conference on Distributed Computing Systems - ICDCS 2009, Jun 2009, Montreal, Canada. pp.404-412, ⟨10.1109/ICDCS.2009.75⟩. ⟨inria-00432368⟩
501 Consultations
12731 Téléchargements
