Drop cost and wavelength optimal two-period grooming with ratio 4 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We study grooming for two-period optical networks, a variation of the traffic grooming problem for WDM ring networks introduced by Colbourn, Quattrocchi, and Syrotiuk. In the two-period grooming problem, during the first period of time, there is all-to-all uniform traffic among $n$ nodes, each request using $1/C$ of the bandwidth; and during the second period, there is all-to-all uniform traffic only among a subset $V$ of $v$ nodes, each request now being allowed to use $1/C'$ of the bandwidth, where $C' < C$. We determine the minimum drop cost (minimum number of ADMs) for any $n,v$ and $C=4$ and $C' \in \{1,2,3\}$. To do this, we use tools of graph decompositions. Indeed the two-period grooming problem corresponds to minimizing the total number of vertices in a partition of the edges of the complete graph $K_n$ into subgraphs, where each subgraph has at most $C$ edges and where furthermore it contains at most $C'$ edges of the complete graph on $v$ specified vertices. Subject to the condition that the two-period grooming has the least drop cost, the minimum number of wavelengths required is also determined in each case.
RR-7101.pdf (249.48 Ko) Télécharger le fichier
inria-00432801 , version 1 (17-11-2009)
  • HAL Id : inria-00432801 , version 1
  • ARXIV : 0911.3475
Jean-Claude Bermond, Charles J. Colbourn, Lucia Gionfriddo, Gaetano Quattrocchi, Ignasi Sau. Drop cost and wavelength optimal two-period grooming with ratio 4. [Research Report] RR-7101, INRIA. 2009, pp.24. ⟨inria-00432801⟩
239 Consultations
126 Téléchargements
