Multiple-View Geometry of the Refractive Plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Transparent refractive objects are one of the main problems in geometric vision that have been largely unexplored. The imaging and multi-view geometry of scenes with transparent or translucent objects with refractive properties is relatively less well understood than for opaque objects. The main objective of our work is to analyze the underlying multi-view relationships between cameras, when the scene being viewed contains a single refractive planar surface separating two different media. Such a situation might occur in scenarios like underwater photography. Our main result is to show the existence of geometric entities like the fundamental matrix, and the homography matrix in such instances. In addition, under special circumstances we also show how to compute the relative pose between two cameras immersed in one of the two media.
CS-BMVC-09.pdf (338.4 Ko) Télécharger le fichier
inria-00434342 , version 1 (24-05-2011)
Visesh Chari, Peter Sturm. Multiple-View Geometry of the Refractive Plane. BMVC 2009 - 20th British Machine Vision Conference, Sep 2009, London, United Kingdom. pp.1-11, ⟨10.5244/C.23.56⟩. ⟨inria-00434342⟩
616 Consultations
824 Téléchargements
