Distributed Gradient Optimization for Epidemic Routing: a preliminary Evaluation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In this research report we address the problem of designing adaptive epidemic-style forwarding mechanisms for message delivery in Delay Tolerant Networks. Our approach is based on a new analytical framework for multi-agent optimization through distributed subgradient methods. We investigate how this framework can be adapted to the considered networking problem and we perform a preliminary evaluation, which shows promising results in terms of convergence speed.
RR-7016.pdf (496.17 Ko) Télécharger le fichier
inria-00435184 , version 1 (23-11-2009)
inria-00435184 , version 2 (24-11-2009)
  • HAL Id : inria-00435184 , version 1
Giovanni Neglia, Giuseppe Reina, Sara Alouf. Distributed Gradient Optimization for Epidemic Routing: a preliminary Evaluation. [Research Report] RR-7016, 2009. ⟨inria-00435184v1⟩
Collections
INRIA-RRRT
134 Consultations
174 Téléchargements
