Some numerical aspects of the conservative PSM scheme in a 4D drift-kinetic code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The purpose of this work is simulation of magnetised plasmas in the ITER pro ject framework. In this context, Vlasov-Poisson like models are used to simulate core turbulence in the tokamak in a toroidal geometry. This leads to heavy simulation because a 6D dimensional problem has to be solved, 3D in space and 3D in velocity. The model is reduced to a 5D gyrokinetic model, taking advantage of the particular motion of particles due to the presence of a strong magnetic field. However, accurate schemes, parallel algorithms need to be designed to bear these simulations. This paper describes the numerical studies to improve robustness of the conservative PSM scheme in the context of its development in the GYSELA code. In this paper, we only consider the 4D drift-kinetic model which is the backbone of the 5D gyrokinetic models and relevant to build a robust and accurate numerical method.
RR-7109.pdf (879.77 Ko) Télécharger le fichier
inria-00435203 , version 1 (26-11-2009)
inria-00435203 , version 2 (09-03-2013)
  • HAL Id : inria-00435203 , version 1
Jean-Philippe Braeunig, Nicolas Crouseilles, Virginie Grandgirard, Guillaume Latu, Michel Mehrenberger, et al.. Some numerical aspects of the conservative PSM scheme in a 4D drift-kinetic code. [Research Report] RR-7109, INRIA. 2009, pp.37. ⟨inria-00435203v1⟩
Collections
INRIA-RRRT
671 Consultations
247 Téléchargements
