SimSoC: A full system simulation software for embedded systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Vania Joloboff
Hui Xiao
  • Fonction : Auteur
  • PersonId : 864941
The development of embedded systems requires the development of increasingly complex software and hardware platforms. Full system simulation makes it possible to run the exact binary embedded software including the operating system on a totally simulated hardware platform. Whereas most simulation environments do not support full system simulation, or do not use any hardware modeling techniques, or have combined different types of technology, SimSoC is developing a full system simulation architecture with an integrated approach relying only upon SystemC hardware modeling and transaction level modeling abstractions (TLM) for communications. To simulate processors at reasonably high speed, SimSoC integrates instruction set simulators (ISS) as SystemC modules with TLM interfaces to the other platform components. The ISS's use a variant approach of dynamic translation to run binary code. The paper describes the overall architecture of the SimSoC full system simulator, a description of the ISS implementation and integration with some other components. The final section reports results obtained, in particular simulation of an existing System On Chip that can run the Linux operating system.
paper.pdf (90.62 Ko) Télécharger le fichier
inria-00435247 , version 1 (12-01-2010)
  • HAL Id : inria-00435247 , version 1
Claude Helmstetter, Vania Joloboff, Hui Xiao. SimSoC: A full system simulation software for embedded systems. 2009 International Workshop on Open-source Software for Scientific Computation (OSSC-2009), LIAMA, Institute of Automation, CAS, Beijing, China Guizhou Normal University, China, Sep 2009, Guiyang, China. 7 p. ⟨inria-00435247⟩
1387 Consultations
1103 Téléchargements
