Control and data channels allocation for Large-Scale UWB-based WSNs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Jamila Ben Sliman
  • Fonction : Auteur
  • PersonId : 853826
Ye-Qiong Song
Resource allocation is a critical issue for Wireless Sensor Networks (WSNs) especially for Ultra-Wide Band (UWB) based networks. In this paper, we present frequency allocation scheme for an efficient spectrum management that is able to statically assign control channels and dynamically reuse data channels for Personal Area Networks (PANs) inside a Large- Scale WSN based on UWB technology. The frequency allocation problem is decomposed into two sub-problems: static control channel assignment and dynamic data channel allocation. The goal is two-folded: first, we aim to avoid congestion of control channel, second, to maximize simultaneous communications without suffering from interference in order to enhance throughput, decrease delay and minimize energy consumption.
Control_and_data_channels_allocation_for_Large-Scale_UWB-based_WSNs.pdf (1.87 Mo) Télécharger le fichier
inria-00435514 , version 1 (24-11-2009)
  • HAL Id : inria-00435514 , version 1
Jamila Ben Sliman, Ye-Qiong Song, Anis Koubâa. Control and data channels allocation for Large-Scale UWB-based WSNs. ComNet'09: The First International Conference on Communications, and Networking, Nov 2009, Hammamet, Tunisia. pp.64. ⟨inria-00435514⟩
135 Consultations
378 Téléchargements
