AA4MM coordination model and event-B specification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We develop a framework called Agent and Artefact forMultipleModels coordination (AA4MM) . It is is intended to make the design and the implementation of complex systems simulation mod- ular and decentralized. Our main goal is to reuse existing models and simulators and to make them interact in order to simulate dierent levels of abstraction. The main constraint is that people involved into the design process do not have to care about anything else but modelling. Coordination challenges remain to the framework. This report presents the event-B specication of the coordination model proposed in [SCC10]. Its goal is to check that the system is never blocked (no deadlock): no simulator is waiting for another indenitely.
RR-7081.pdf (142.04 Ko) Télécharger le fichier
inria-00435569 , version 1 (24-11-2009)
inria-00435569 , version 2 (02-12-2009)
inria-00435569 , version 3 (06-04-2010)
  • HAL Id : inria-00435569 , version 2
Julien Siebert, Joris Rehm, Vincent Chevrier, Laurent Ciarletta, Dominique Méry. AA4MM coordination model and event-B specification. [Research Report] 7081, 2009, pp.22. ⟨inria-00435569v2⟩
245 Consultations
216 Téléchargements
