SimGrid: a Generic Framework for Large-Scale Distributed Experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Martin Quinson
In this paper we describe a comprehensive simulation framework, SimGrid, for the simulation of distributed applications on distributed platforms. Our goal is to describe the salient capabilities of SimGrid and explain how they allow users to perform simulations for a wide range of applications and platforms.
tuto_p2p.pdf (53.58 Ko) Télécharger le fichier
090909-P2P.pdf (522.31 Ko) Télécharger le fichier
Format : Autre
inria-00435802 , version 1 (24-11-2009)
  • HAL Id : inria-00435802 , version 1
Martin Quinson. SimGrid: a Generic Framework for Large-Scale Distributed Experiments. 9th International conference on Peer-to-peer computing - IEEE P2P 2009, Sep 2009, Seattle, United States. ⟨inria-00435802⟩
81 Consultations
233 Téléchargements
