Multicamera Real-Time 3D Modeling for Telepresence and Remote Collaboration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Digital Multimedia Broadcasting Année : 2010
We present a multicamera real-time 3D modeling system that aims at enabling new immersive and interactive environments. This system, called Grimage, allows to retrieve in real-time a 3D mesh of the observed scene as well as the associated textures. This information enables a strong visual presence of the user into virtual worlds. The 3D shape information is also used to compute collisions and reaction forces with virtual objects, enforcing the mechanical presence of the user in the virtual world. The innovation is a fully integrated system with both immersive and interactive capabilities. It embeds a parallel version of the EPVH modeling algorithm inside a distributed vision pipeline. It also adopts the hierarchical component approach of the FlowVR middleware to enforce software modularity and enable distributed executions. Results show high refresh rates and low latencies obtained by taking advantage of the I/O and computing resources of PC clusters. The applications we have developed demonstrate the quality of the visual and mechanical presence with a single platform and with a dual platform that allows telecollaboration.
petit09c.pdf (2.5 Mo) Télécharger le fichier
inria-00436467 , version 1 (27-11-2009)
inria-00436467 , version 2 (06-09-2010)
inria-00436467 , version 3 (18-04-2012)
  • HAL Id : inria-00436467 , version 1
Benjamin Petit, Jean-Denis Lesage, Menier Clément, Jérémie Allard, Jean-Sébastien Franco, et al.. Multicamera Real-Time 3D Modeling for Telepresence and Remote Collaboration. International Journal of Digital Multimedia Broadcasting, 2010, Article ID 247108, 12 p. ⟨inria-00436467v1⟩
Collections
LIG_SRCPR
2558 Consultations
1029 Téléchargements
