Coarsely Calibrated Visual Servoing of a Mobile Robot using a Catadioptric Vision System
A catadioptric vision system combines a camera and a mirror to achieve a wide field of view imaging system. This type of vision system has many potential applications in mobile robotics. This paper is concerned with the design of a robust image-based control scheme using a catadioptric vision system mounted on a mobile robot. We exploit the fact that the decoupling property contributes to the robustness of a control method. More precisely, from the image of a point, we propose a minimal and decoupled set of features measurable on any catadioptric vision system. Using the minimal set, a classical control method is proved to be robust in the presence of point range errors. Finally, experimental results with a coarsely calibrated mobile robot validate the robustness of the new decoupled scheme.
Robotique [cs.RO]
