TagProp: Discriminative metric learning in nearest neighbor models for image auto-annotation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Thomas Mensink
  • Fonction : Auteur
  • PersonId : 853681
Jakob Verbeek
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
Image auto-annotation is an important open problem in computer vision. For this task we propose TagProp, a discriminatively trained nearest neighbor model. Tags of test images are predicted using a weighted nearest-neighbor model to exploit labeled training images. Neighbor weights are based on neighbor rank or distance. TagProp allows the integration of metric learning by directly maximizing the log-likelihood of the tag predictions in the training set. In this manner, we can optimally combine a collection of image similarity metrics that cover different aspects of image content, such as local shape descriptors, or global color histograms. We also introduce a word specific sigmoidal modulation of the weighted neighbor tag predictions to boost the recall of rare words. We investigate the performance of different variants of our model and compare to existing work. We present experimental results for three challenging data sets. On all three, TagProp makes a marked improvement as compared to the current state-of-the-art.
GMVS09.pdf (239.37 Ko) Télécharger le fichier
SupplMat.pdf (6.24 Mo) Télécharger le fichier
slides.pdf (2.15 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00439276 , version 1 (02-12-2010)
Matthieu Guillaumin, Thomas Mensink, Jakob Verbeek, Cordelia Schmid. TagProp: Discriminative metric learning in nearest neighbor models for image auto-annotation. ICCV 2009 - 12th International Conference on Computer Vision, Sep 2009, Kyoto, Japan. pp.309-316, ⟨10.1109/ICCV.2009.5459266⟩. ⟨inria-00439276⟩
659 Consultations
3095 Téléchargements
