BlobSeer: Bringing High Throughput under Heavy Concurrency to Hadoop Map/Reduce Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Bogdan Nicolae
  • Fonction : Auteur
  • PersonId : 862774
Diana Moise
  • Fonction : Auteur
  • PersonId : 856286
Luc Bougé
Matthieu Dorier
  • Fonction : Auteur
  • PersonId : 865414
Hadoop is a software framework supporting the Map/Reduce programming model. It relies on the Hadoop Distributed File System (HDFS) as its primary storage system. The efficiency of HDFS is crucial for the performance of Map/Reduce applications. We substitute the original HDFS layer of Hadoop with a new, concurrency-optimized data storage layer based on the BlobSeer data management service. Thereby, the efficiency of Hadoop is significantly improved for data-intensive Map/Reduce applications, which naturally exhibit a high degree of data access concurrency. Moreover, BlobSeer's features (built-in versioning, its support for concurrent append operations) open the possibility for Hadoop to further extend its functionalities. We report on extensive experiments conducted on the Grid'5000 testbed. The results illustrate the benefits of our approach over the original HDFS-based implementation of Hadoop.
rr-7140.pdf (357.74 Ko) Télécharger le fichier
inria-00440312 , version 1 (10-12-2009)
  • HAL Id : inria-00440312 , version 1
Bogdan Nicolae, Diana Moise, Gabriel Antoniu, Luc Bougé, Matthieu Dorier. BlobSeer: Bringing High Throughput under Heavy Concurrency to Hadoop Map/Reduce Applications. [Research Report] RR-7140, INRIA. 2009, pp.20. ⟨inria-00440312⟩
240 Consultations
379 Téléchargements
