Implementation of Bourbaki's Elements of Mathematics in Coq: Part Two; Ordered Sets, Cardinals, Integers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
We believe that it is possible to put the whole work of Bourbaki into a computer. One of the objectives of the Gaia project concerns homological algebra (theory as well as algorithms); in a first step we want to implement all nine chapters of the book Algebra. But this requires a theory of sets (with axiom of choice, etc.) more powerful than what is provided by Ensembles; we have chosen the work of Carlos Simpson as basis. This reports lists and comments all definitions and theorems of the Chapter ''Ordered Sets, Cardinals, Integers''. Version 3 is based on the Coq ssreflect library. Version 5 implements many properties of ordinal numbers and infinite cardinal numbers. The code (including some exercises) is available on the Web, under http://www-sop.inria.fr/apics/gaia .
RR7150-v5.pdf (1.98 Mo) Télécharger le fichier
inria-00440786 , version 1 (11-12-2009)
inria-00440786 , version 2 (01-04-2010)
inria-00440786 , version 3 (02-12-2010)
inria-00440786 , version 4 (21-12-2011)
inria-00440786 , version 5 (22-12-2011)
inria-00440786 , version 6 (29-11-2013)
inria-00440786 , version 7 (16-01-2015)
inria-00440786 , version 8 (09-12-2016)
inria-00440786 , version 9 (29-11-2017)
inria-00440786 , version 10 (05-12-2018)
  • HAL Id : inria-00440786 , version 5
José Grimm. Implementation of Bourbaki's Elements of Mathematics in Coq: Part Two; Ordered Sets, Cardinals, Integers. [Research Report] RR-7150, 2011, pp.446. ⟨inria-00440786v5⟩
1016 Consultations
1363 Téléchargements
