Set Systems and Families of Permutations with Small Traces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We study the maximum size of a set system on $n$ elements whose trace on any $b$ elements has size at most $k$. We show that if for some $b \ge i \ge 0$ the shatter function $f_R$ of a set system $([n],R)$ satisfies $f_R(b) < 2^i(b-i+1)$ then $|R| = O(n^i)$; this generalizes Sauer's Lemma on the size of set systems with bounded VC-dimension. We use this bound to delineate the main growth rates for the same problem on families of permutations, where the trace corresponds to the inclusion for permutations. This is related to a question of Raz on families of permutations with bounded VC-dimension that generalizes the Stanley-Wilf conjecture on permutations with excluded patterns.
RR-7154.pdf (212.56 Ko) Télécharger le fichier
inria-00441376 , version 1 (15-12-2009)
inria-00441376 , version 2 (17-12-2009)
  • HAL Id : inria-00441376 , version 2
  • ARXIV : 0912.2979
Otfried Cheong, Xavier Goaoc, Cyril Nicaud. Set Systems and Families of Permutations with Small Traces. [Research Report] RR-7154, INRIA. 2009, pp.14. ⟨inria-00441376v2⟩
235 Consultations
296 Téléchargements
