Improvement of Schedulability Analysis with a Priority Share Policy in On-Chip Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Alan Burns
  • Fonction : Auteur
  • PersonId : 855209
Priority-based wormhole switching with a priority share policy has been proposed as a possible solution for real-time on-chip communication. However, the blocking introduced by priority share complicates the analysis process. In this paper, we propose a new “per-priority” basis analysis scheme which computes the total time window at each priority level instead of each traffic-flow. By checking the release instance of each flow at the corresponding priority window, we can determine schedulability efficiently.
Networks_Shi.pdf (4.71 Mo) Télécharger le fichier
inria-00441970 , version 1 (17-12-2009)
  • HAL Id : inria-00441970 , version 1
Zheng Shi, Alan Burns. Improvement of Schedulability Analysis with a Priority Share Policy in On-Chip Networks. 17th International Conference on Real-Time and Network Systems, Oct 2009, Paris, France. pp.75-84. ⟨inria-00441970⟩
Collections
RTNS2009
84 Consultations
78 Téléchargements
