Nonconvergence of the plain Newton-min algorithm for linear complementarity problems with a P-matrix. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The plain Newton-min algorithm for solving the linear complementarity problem (LCP for short) 0≤ x \perp Mx+q ≥0 can be viewed as a nonsmooth Newton algorithm without globalization technique to solve the system of piecewise linear equations min(x,Mx+q)=0 , which is equivalent to the LCP. When M is an M-matrix of order n, the algorithm is known to converge in at most n iterations. We show in this note that this result no longer holds when M is a P-matrix of order n ≥3, since then the algorithm may cycle. P-matrices are interesting since they are those ensuring the existence and uniqueness of the solution to the LCP for an arbitrary q. Incidentally, convergence occurs for a P-matrix of order 1 or 2.
RR-7160.pdf (501.31 Ko) Télécharger le fichier
inria-00442293 , version 1 (19-12-2009)
inria-00442293 , version 2 (11-04-2010)
inria-00442293 , version 3 (27-09-2010)
inria-00442293 , version 4 (28-12-2010)
inria-00442293 , version 5 (17-12-2012)
  • HAL Id : inria-00442293 , version 1
Ibtihel Ben Gharbia, Jean Charles Gilbert. Nonconvergence of the plain Newton-min algorithm for linear complementarity problems with a P-matrix.. [Research Report] RR-7160, 2009. ⟨inria-00442293v1⟩
Collections
INRIA-RRRT
364 Consultations
408 Téléchargements
