A CDMA Secure Optical Access Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
We propose a CDMA network implementation that enhances security at the physical layer. By using an active star topology supporting both point-to-point and point-to-multipoint communication, 128 ONUs can transmit simultaneously at rates of at least 12 Mbps, with a reach of 20 km, thus addressing access network applications. Numerical simulations demonstrate the feasibility of the proposed scheme.
Notre_arxiv.pdf (138.2 Ko) Télécharger le fichier
inria-00443517 , version 1 (29-12-2009)
inria-00443517 , version 2 (14-09-2010)
inria-00443517 , version 3 (03-02-2011)
  • HAL Id : inria-00443517 , version 2
  • ARXIV : 0912.5324
Ortega A. Alfredo, Victor A. Bettachini, José Ignacio Alvarez-Hamelin, Diego F. Grosz. A CDMA Secure Optical Access Network. 2009. ⟨inria-00443517v2⟩
60 Consultations
322 Téléchargements
