The Speedup Test - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2010
The Speedup Test
Numerous code optimisation methods are usually experimented by doing multiple observations of the initial and the optimised executions times in order to declare a speedup. Even with fixed input and execution environment, programs executions times vary in general. So hence different kinds of speedups may be reported: the speedup of the average execution time, the speedup of the minimal execution time, the speedup of the median, etc. Many published speedups in the literature are observations of a set of experiments. In order to improve the reproducibility of the experimental results, this technical report presents a rigorous statistical methodology regarding program performance analysis. We rely on well known statistical tests (Shapiro-wilk's test, Fisher's F-test, Student's t-test, Kolmogorov-Smirnov's test, Wilcoxon-Mann-Whitney's test) to study if the observed speedups are statistically significant or not. By fixing $0<\alpha<1$ a desired risk level, we are able to analyse the statistical significance of the average execution time as well as the median. We can also check if $\prob{X>Y}>\frac{1}{2}$, the probability that an individual execution of the optimised code is faster than the individual execution of the initial code. Our methodology defines a consistent improvement compared to the usual performance analysis method in high performance computing as in \cite{Jain:1991:ACS,lilja:book}. We explain in each situation what are the hypothesis that must be checked to declare a correct risk level for the statistics. The Speedup-Test protocol certifying the observed speedups with rigorous statistics is implemented and distributed as an open source tool based on R software.
SpeedupTestDocument.pdf (399.13 Ko) Télécharger le fichier
SpeedupTestTool.tar.bz2 (603.74 Ko) Télécharger le fichier
Format : Autre
inria-00443839 , version 1 (07-01-2010)
inria-00443839 , version 2 (26-01-2010)
  • HAL Id : inria-00443839 , version 1
Sid Touati, Julien Worms, Sébastien Briais. The Speedup Test. [Technical Report] 2010, pp.35. ⟨inria-00443839v1⟩
1576 Consultations
1261 Téléchargements
