On-Line Monitoring of Random Number Generators for Embedded Security - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Many embedded security chips require a high- quality Random Number Generator (RNG). Unfortunately, hard- ware RNG randomness can vary in time due to implementation defects or certain kinds of attacks. To overcome this issue, this paper presents the implementation of a battery of statistical test for randomness. The battery is selected for its efficient imple- mentation, making the area and power consumption insignificant. Performance and cost of the hardware implementation are given for FPGA and VLSI targets. Results show that statistical tests can easily be implemented in low-cost embedded security circuits and can enhance on-line monitoring of RNG randomness to prevent RNG failures.
Santoro09.pdf (120.57 Ko) Télécharger le fichier
inria-00446036 , version 1 (11-01-2010)
Renaud Santoro, Olivier Sentieys, Sébastien Roy. On-Line Monitoring of Random Number Generators for Embedded Security. IEEE International Symposium on Circuits and Systems, ISCAS 2009, May 2009, Taipei, Taiwan. ⟨10.1109/ISCAS.2009.5118446⟩. ⟨inria-00446036⟩
215 Consultations
761 Téléchargements
