Inexact Matching of Large and Sparse Graphs Using Laplacian Eigenvectors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we propose an inexact spectral matching algorithm that embeds large graphs on a low-dimensional isometric space spanned by a set of eigenvectors of the graph Laplacian. Given two sets of eigenvectors that correspond to the smallest non-null eigenvalues of the Laplacian matrices of two graphs, we project each graph onto its eigenenvectors. We estimate the histograms of these one-dimensional graph projections (eigenvector histograms) and we show that these histograms are well suited for selecting a subset of significant eigenvectors, for ordering them, for solving the sign-ambiguity of eigenvector computation, and for aligning two embeddings. This results in an inexact graph matching solution that can be improved using a rigid point registration algorithm. We apply the proposed methodology to match surfaces represented by meshes.
KnossowSharmaMateusHoraud-GbR.pdf (2.05 Mo) Télécharger le fichier
Format : Figure, Image
inria-00446989 , version 1 (13-01-2010)
David Knossow, Avinash Sharma, Diana Mateus, Radu Horaud. Inexact Matching of Large and Sparse Graphs Using Laplacian Eigenvectors. 7th International Workshop on Graph-Based Representations in Pattern Recognition, May 2009, Venice, Italy. pp.144-153, ⟨10.1007/978-3-642-02124-4_15⟩. ⟨inria-00446989⟩
715 Consultations
2073 Téléchargements
