Class invariants by the CRT method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
We adapt the CRT approach to computing Hilbert class polynomials to handle a wide range of class invariants. For suitable discriminants $D$, this improves its performance by a large constant factor, more than 200 in the most favourable circumstances. This has enabled record-breaking constructions of elliptic curves via the CM method, including examples with $|D|>10^{15}$.
classinv.pdf (236.34 Ko) Télécharger le fichier
inria-00448729 , version 1 (19-01-2010)
inria-00448729 , version 2 (01-05-2010)
  • HAL Id : inria-00448729 , version 1
  • ARXIV : 1001.3394
Andreas Enge, Andrew V. Sutherland. Class invariants by the CRT method. 2010. ⟨inria-00448729v1⟩
208 Consultations
252 Téléchargements
