ACCURACY EVALUATION OF FIXED-POINT BASED LMS ALGORITHM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Digital Signal Processing Année : 2010
The implementation of adaptive filters with fixed-point arithmetic requires computation quality evaluation. The accuracy may be determined by computing the global quantization noise power at the system output. In this paper, a new model for evaluating analytically the global noise power in LMS-based algorithms is presented. Thus, the model is developed for LMS and NLMS algorithms. The accuracy of our model is analyzed by simulations.
Fichier non déposé
inria-00450935 , version 1 (27-01-2010)
  • HAL Id : inria-00450935 , version 1
Romuald Rocher, Daniel Ménard, Olivier Sentieys, Pascal Scalart. ACCURACY EVALUATION OF FIXED-POINT BASED LMS ALGORITHM. Digital Signal Processing, 2010. ⟨inria-00450935⟩
225 Consultations
0 Téléchargements
