Bandit-Based Genetic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the validation of randomly generated patterns in a Monte-Carlo Tree Search program. Our bandit-based genetic programming (BGP) algorithm, with proved mathematical properties, outperformed a highly optimized handcrafted module of a well-known computer-Go program with several world records in the game of Go.
pattern.pdf (198.97 Ko) Télécharger le fichier
inria-00452887 , version 1 (15-02-2010)
inria-00452887 , version 2 (14-06-2011)
  • HAL Id : inria-00452887 , version 1
Jean-Baptiste Hoock, Olivier Teytaud. Bandit-Based Genetic Programming. 13th European Conference on Genetic Programming, Apr 2010, Istanbul, Turkey. ⟨inria-00452887v1⟩
355 Consultations
439 Téléchargements
