The Traveling Salesman Problem Under Squared Euclidean Distances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Let $P$ be a set of points in $\mathbb{R}^d$, and let $\alpha \ge 1$ be a real number. We define the distance between two points $p,q\in P$ as $|pq|^{\alpha}$, where $|pq|$ denotes the standard Euclidean distance between $p$ and $q$. We denote the traveling salesman problem under this distance function by TSP($d,\alpha$). We design a 5-approximation algorithm for TSP(2,2) and generalize this result to obtain an approximation factor of $3^{\alpha-1}+\sqrt{6}^{\alpha}/3$ for $d=2$ and all $\alpha\ge2$. We also study the variant Rev-TSP of the problem where the traveling salesman is allowed to revisit points. We present a polynomial-time approximation scheme for Rev-TSP$(2,\alpha)$ with $\alpha\ge2$, and we show that Rev-TSP$(d, \alpha)$ is APX-hard if $d\ge3$ and $\alpha>1$. The APX-hardness proof carries over to TSP$(d, \alpha)$ for the same parameter ranges.
deberg.pdf (254.33 Ko) Télécharger le fichier
inria-00455193 , version 1 (09-02-2010)
  • HAL Id : inria-00455193 , version 1
Mark de Berg, Fred van Nijnatten, Rene Sitters, Gerhard J. Woeginger, Alexander Wolff. The Traveling Salesman Problem Under Squared Euclidean Distances. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.239-250. ⟨inria-00455193⟩
Collections
STACS2010
95 Consultations
1015 Téléchargements
