Treewidth reduction for constrained separation and bipartization problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dániel Marx
  • Fonction : Auteur correspondant
  • PersonId : 857864
Connectez-vous pour contacter l'auteur
Barry O'Sullivan
  • Fonction : Auteur
  • PersonId : 849989
Igor Razgon
  • Fonction : Auteur
  • PersonId : 867177
We present a method for reducing the treewidth of a graph while preserving all the minimal $s-t$ separators. This technique turns out to be very useful for establishing the fixed-parameter tractability of constrained separation and bipartization problems. To demonstrate the power of this technique, we prove the fixed-parameter tractability of a number of well-known separation and bipartization problems with various additional restrictions (e.g., the vertices being removed from the graph form an independent set). These results answer a number of open questions in the area of parameterized complexity.
Marx.pdf (165.38 Ko) Télécharger le fichier
inria-00455767 , version 1 (11-02-2010)
  • HAL Id : inria-00455767 , version 1
Dániel Marx, Barry O'Sullivan, Igor Razgon. Treewidth reduction for constrained separation and bipartization problems. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.561-572. ⟨inria-00455767⟩
Collections
STACS2010 TDS-MACS
67 Consultations
209 Téléchargements
