A Model-driven Measurement Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Companies using domain specific languages in a model-driven development process need to measure their models. However, developing and maintaining a measurement software for each domain specific mod- eling language is costly. Our contribution is a model-driven measurement approach. This measurement approach is model-driven from two view- points: 1) it measures models of a model-driven development process; 2) it uses models as unique and consistent metric specifications, w.r.t a metric specification metamodel. This declarative specification of metrics is then used to generate a fully fledged implementation. The benefit from applying the approach is evaluated by two applications. They indicate that this approach reduces the domain-specific measurement software development cost.
Monperrus08d.pdf (322.45 Ko) Télécharger le fichier
inria-00456483 , version 1 (15-02-2010)
Martin Monperrus, Jean-Marc Jézéquel, Joël Champeau, Brigitte Hoeltzener. A Model-driven Measurement Approach. ACM/IEEE 11th International Conference on Model Driven Engineering Languages and Systems (MoDELS 08), Sep 2008, Toulouse, France, France. pp.505-519, ⟨10.1007/978-3-540-87875-9_36⟩. ⟨inria-00456483⟩
305 Consultations
274 Téléchargements
