PRISM: probabilistic model checking for performance and reliability analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM SIGMETRICS Performance Evaluation Review Année : 2009
Marta Kwiatkowska
  • Fonction : Auteur
  • PersonId : 861066
Probabilistic model checking is a formal verification technique for the modelling and analysis of stochastic systems. It has proved to be useful for studying a wide range of quantitative properties of models taken from many diffierent application domains. This includes, for example, performance and reliability properties of computer and communication systems. In this paper, we give an overview of the probabilistic model checking tool PRISM, focusing in particular on its support for continuous-time Markov chains and Markov reward models, and how these can be used to analyse performability properties.
acmper_prismperf.pdf (328.82 Ko) Télécharger le fichier
inria-00457906 , version 1 (18-02-2010)
Marta Kwiatkowska, Gethin Norman, David Parker. PRISM: probabilistic model checking for performance and reliability analysis. ACM SIGMETRICS Performance Evaluation Review, 2009, 36 (4), pp.40-45. ⟨10.1145/1530873.1530882⟩. ⟨inria-00457906⟩
Collections
CONNECT
147 Consultations
1158 Téléchargements
