Supporting Heterogeneity in Data Driven Sensor Network Macroprogramming
Support for heterogeneity has been incorporated within a Macroprogramming framework. Policies for handling runtime and data routing for communication between nodes in a heterogeneous network were designed and implemented. Then, Macroprogramming support was added to compile Macroprograms and generate code for the heterogeneous network.
Informatique mobile
