Vers une simplification de la commande non linéaire : l'exemple d'un avion à décollage vertical - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
``Model-Free Control'' and ``Control with a Restricted Model'', which were recently introduced, yield an elementary and easy to tune control strategy for a ``Planar Vertical Take-off and Landing'' (PVTOL) aircraft, which has been largely studied in the academic literature via various advanced nonlinear control techniques. The efficiency of our approach is demonstrated by several convincing computer simulations.
PVTOL-CIFA10.pdf (1.41 Mo) Télécharger le fichier
inria-00463605 , version 1 (12-03-2010)
  • HAL Id : inria-00463605 , version 1
Samer Riachy, Michel Fliess, Cédric Join, Jean-Pierre Barbot. Vers une simplification de la commande non linéaire : l'exemple d'un avion à décollage vertical. Sixième Conférence Internationale Francophone d'Automatique, CIFA 2010, Jun 2010, Nancy, France. pp.CDROM. ⟨inria-00463605⟩
502 Consultations
351 Téléchargements
