Initial CONNECT Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2010
Interoperability remains a fundamental challenge when connecting heterogeneous systems which encounter and spontaneously communicate with one another in pervasive computing environments. This challenge is exasperated by the highly heterogeneous technologies employed by each of the interacting parties, i.e., in terms of hardware, operating system, middleware protocols, and application protocols. The key aim of the CONNECT project is to drop this heterogeneity barrier and achieve universal interoperability. Here we report on the development of the overall CONNECT architecture that will underpin this solution; in this respect, we present the following contributions: i) an elicitation of interoperability requirements from a set of pervasive computing scenarios, ii) a survey of existing solutions to interoperability, iii) an initial view of the CONNECT architecture, and iv) a series of experiments to provide initial validation of the architecture.
connect_WP1_D11_300dpi_.pdf (6.96 Mo) Télécharger le fichier
inria-00464644 , version 1 (17-03-2010)
  • HAL Id : inria-00464644 , version 1
Antonia Bertolino, Gordon Blair, Franck Chauvel, Carlos Flores Cortes, Nikolaos Georgantas, et al.. Initial CONNECT Architecture. [Technical Report] 2010. ⟨inria-00464644⟩
166 Consultations
158 Téléchargements
