A Note on Integer Factorization Using Lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We revisit Schnorr's lattice-based integer factorization algorithm, now with an effective point of view. We present effective versions of Theorem 2 of Schnorr's "Factoring integers and computing discrete logarithms via diophantine approximation" paper, as well as new elementary properties of the Prime Number Lattice bases of Schnorr and Adleman.
A_Note_on_Integer_Factorization__Antonio_Vera.pdf (180.9 Ko) Télécharger le fichier
inria-00467590 , version 1 (27-03-2010)
  • HAL Id : inria-00467590 , version 1
  • ARXIV : 1003.5461
Antonio Ignacio Vera. A Note on Integer Factorization Using Lattices. [Research Report] 2010, pp.12. ⟨inria-00467590⟩
187 Consultations
909 Téléchargements
