Combining Aspect and Model-Driven Engineering Approaches for Software Process Modeling and Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
One major advantage of executable software process models is that once defined, they can be simulated, checked and validated in short incremental and iterative cycles. This also makes them a powerful asset for important process improvement decisions such as resource allocation, deadlock identification and process management. In this paper, we propose a framework that combines Aspect and Model-Driven Engineering approaches in order to ensure process modeling, simulation and execution. This framework is based upon UML4SPM, a UML2.0-based language for Software Process Modeling and Kermeta, an executable metaprogramming language.
Bendraou09a.pdf (160.01 Ko) Télécharger le fichier
inria-00468652 , version 1 (31-03-2010)
Reda Bendraou, Jean-Marc Jézéquel, Franck Fleurey. Combining Aspect and Model-Driven Engineering Approaches for Software Process Modeling and Simulation. ICSP 2009 - International Conference on Software Process, May 2009, Vancouver, Canada. pp.148-160, ⟨10.1007/978-3-642-01680-6_15⟩. ⟨inria-00468652⟩
326 Consultations
163 Téléchargements
