On the Holonomy or Algebraicity of Generating Functions Counting Lattice Walks in the Quarter-Plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Markov Processes And Related Fields Année : 2010
In two recent works \cite{BMM,BK}, it has been shown that the counting generating functions (CGF) for the 23 walks with small steps confined in a quadrant and associated with a finite group of birational transformations are holonomic, and even algebraic in 4 cases -- in particular for the so-called Gessel's walk. It turns out that the type of functional equations satisfied by these CGF appeared in a probabilistic context almost 40 years ago. Then a method of resolution was proposed in \cite{FIM}, involving at once algebraic tools and a reduction to boundary value problems. Recently this method has been developed in a combinatorics framework in \cite{Ra}, where a thorough study of the explicit expressions for the CGF is proposed. The aim of this paper is to derive the nature of the bivariate CGF by a direct use of some general theorems given in \cite{FIM}.
RR-7242.pdf (232.46 Ko) Télécharger le fichier
inria-00469603 , version 1 (02-04-2010)
  • HAL Id : inria-00469603 , version 1
  • ARXIV : 1004.1733
Guy Fayolle, Kilian Raschel. On the Holonomy or Algebraicity of Generating Functions Counting Lattice Walks in the Quarter-Plane. Markov Processes And Related Fields, 2010, 16 (3), pp.485-496. ⟨inria-00469603⟩
338 Consultations
143 Téléchargements
