Multi-mode relaying for power consumption reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
As multi-mode is becoming standard in current mobile terminals, the necessity to reduce power consumption increases. In this paper, we propose to utilize multi-mode to cut the energy needs, by relaying on the least power consuming communication mode. The most convenient way to implement multi-mode is undoubtfully provided by Software Defined Radio (SDR). The idea is to replace the ever-increasing embedded radio chips by a single, general purpose, processor. We show that a multi-mode relay, composed of Software Defined Radios, has an impact on power reduction. We elaborate different scenarios to verify this proposition, considering that this multi-mode ability is based on an SDR. Firstly, we propose an 802.11g-to-UMTS relay scheme, where a mobile terminal relays other users' signal. We enounce different rules to minimize the global power consumption through multi-mode relaying. Then, we find different results for an 802.15.4-to-802.11g relay. After further inquiries, we explain how the most intuitive solution is not always the best one. Following a more realistic approach, we use network simulations to determine the important parameters having an impact on power consumption.
squelette-rr.pdf (254.82 Ko) Télécharger le fichier
inria-00470533 , version 1 (06-04-2010)
inria-00470533 , version 2 (07-04-2010)
inria-00470533 , version 3 (25-10-2010)
  • HAL Id : inria-00470533 , version 1
Cédric Lévy-Bencheton, Guillaume Villemaud, Tanguy Risset, Doreid Ammar, Clément Reboul. Multi-mode relaying for power consumption reduction. [Research Report] RR-7245, 2010. ⟨inria-00470533v1⟩
Collections
INRIA-RRRT
232 Consultations
227 Téléchargements
