Determining point correspondences between two views under geometric constraint and photometric consistency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Matching or tracking points of interest between several views is one of the keystones of many computer vision applications, especially when considering structure and motion estimation. The procedure generally consists in several independent steps, basically 1) point of interest extraction, 2) point of interest matching by keeping only the ``best correspondences'' with respect to similarity between some local descriptors, 3) correspondence pruning to keep those consistent with an estimated camera motion (here, consistent with epipolar constraints or homography transformation). Each step in itself is a touchy task which may endanger the whole process. In particular, repeated patterns give lots of false matches in step 2) which are hardly, if never, recovered by step 3). Starting from a statistical model by Moisan and Stival, we propose a new one-stage approach to steps 2) and 3), which does not need tricky parameters. The advantage of the proposed method is its robustness to repeated patterns.
RR-7246.pdf (3.13 Mo) Télécharger le fichier
inria-00471874 , version 1 (09-04-2010)
  • HAL Id : inria-00471874 , version 1
Nicolas Noury, Frédéric Sur, Marie-Odile Berger. Determining point correspondences between two views under geometric constraint and photometric consistency. [Research Report] RR-7246, INRIA. 2010. ⟨inria-00471874⟩
181 Consultations
556 Téléchargements
