Mirrored Sampling and Sequential Selection for Evolution Strategies - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2010
Anne Auger
  • Function : Author
  • PersonId : 751513
  • IdHAL : anne-auger
Dimo Brockhoff
Nikolaus Hansen
This paper reveals the surprising result that a single-parent non-elitist evolution strategy (ES) can be locally faster than the (1+1)-ES. The result is brought by mirrored sampling and sequential selection. With mirrored sampling, two offspring are generated symmetrically or mirrored with respect to their parent. In sequential selection, the offspring are evaluated sequentially and the iteration is concluded as soon as one offspring is better than the current parent. Both concepts complement each other well. We derive exact convergence rates of the $(1,\lambda)$-ES with mirrored sampling and/or sequential selection on the sphere model. The log-linear convergence of the ES is preserved. Both methods lead to an improvement and in combination they can sometimes even double the convergence rate. Naively implemented into the CMA-ES with recombination, mirrored sampling leads to a bias on the step-size. However, the (1,4)-CMA-ES with mirrored sampling and sequential selection is unbiased and appears to be faster, more robust, and as local as the (1+1)-CMA-ES.
RR-7249.pdf (588.49 Ko) Télécharger le fichier
Dates and versions
inria-00472650 , version 1 (15-05-2010)
inria-00472650 , version 2 (17-06-2010)
Identifiers
  • HAL Id : inria-00472650 , version 2
Cite
Anne Auger, Dimo Brockhoff, Nikolaus Hansen. Mirrored Sampling and Sequential Selection for Evolution Strategies. [Research Report] RR-7249, INRIA. 2010. ⟨inria-00472650v2⟩
301 View
789 Download
Share
