A Tree Logic with Graded Paths and Nominals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Regular tree grammars and regular path expressions constitute core constructs widely used in programming languages and type systems. Nevertheless, there has been little research so far on reasoning frameworks for path expressions where node cardinality constraints occur along a path in a tree. We present a logic capable of expressing deep counting along paths which may include arbitrary recursive forward and backward navigation. The counting extensions can be seen as a generalization of graded modalities that count immediate successor nodes. While the combination of graded modalities, nominals, and inverse modalities yields undecidable logics over graphs, we show that these features can be combined in a tree logic decidable in exponential time.
RR-7251.pdf (692.58 Ko) Télécharger le fichier
inria-00473160 , version 1 (14-04-2010)
inria-00473160 , version 2 (24-08-2010)
  • HAL Id : inria-00473160 , version 1
Everardo Barcenas, Pierre Genevès, Nabil Layaïda, Alan Schmitt. A Tree Logic with Graded Paths and Nominals. [Research Report] RR-7251, 2010. ⟨inria-00473160v1⟩
338 Consultations
139 Téléchargements
