Adaptive Strategy Selection within Differential Evolution on the BBOB-2010 Noiseless Benchmark - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Álvaro Fialho
  • Fonction : Auteur
  • PersonId : 849053
Raymond Ros
  • Fonction : Auteur
  • PersonId : 868664
This document presents the adaptive strategy selection Fitness-Based Area-Under-Curve Bandit (F-AUC-Bandit) and its use in the context of a continuous optimization algorithm: Differential Evolution. Experimental results were obtained on a testbed of noiseless functions. They demonstrate the interest of using an adaptive strategy selection technique as opposed to the naïve approach which consists in the use of a unique strategy of the optimization algorithm chosen initially. Performance comparisons are made between F-AUC-Bandit and a uniform strategy selection approach and also other adaptive selection strategies. Finally a comparison to the state-of-the-art CMA-ES optimizer is made. Results of the optimization algorithm using F-AUC-Bandit are still not comparable to those of CMA-ES but demonstrate a big improvement on the use of the basic DE.
RR-7259.pdf (10.67 Mo) Télécharger le fichier
inria-00476160 , version 1 (23-04-2010)
inria-00476160 , version 2 (30-04-2010)
  • HAL Id : inria-00476160 , version 1
Álvaro Fialho, Raymond Ros. Adaptive Strategy Selection within Differential Evolution on the BBOB-2010 Noiseless Benchmark. [Research Report] RR-7259, 2010. ⟨inria-00476160v1⟩
Collections
INRIA-RRRT
211 Consultations
107 Téléchargements
