PLiBS: an Eclipse-based tool for Software Product Line Behavior Engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper presents the PLiBS (Product Line Behavior Synthesis), an Eclipse-based tool for modeling and deriving behavior aspects in Software Product Lines (SPL). PLiBS allows specifying SPL behaviors using UML2 sequence diagrams extended by variability mechanisms. PLiBS implements a two-step approach to derive product behaviors. The first one uses model transformation to specialize sequence diagrams. While the second one uses UML state machines synthesis from sequence diagrams. This paper presents a guided tour around PLiBS. It presents its architecture and its main components. It also illustrates its uses on the Banking Product Line example.
Ziadi07a.pdf (489.43 Ko) Télécharger le fichier
inria-00477546 , version 1 (29-04-2010)
  • HAL Id : inria-00477546 , version 1
Tewfik Ziadi, Jean-Marc Jézéquel. PLiBS: an Eclipse-based tool for Software Product Line Behavior Engineering. 3rd Workshop on Managing Variability for Software Product Lines (SPLC 2007), Sep 2007, Kyoto, Japan. ⟨inria-00477546⟩
431 Consultations
100 Téléchargements
