Information Flow in Interactive Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We consider the problem of defining the information leakage in interactive systems where secrets and observables can alternate during the computation. We show that the information-theoretic approach which interprets such systems as (simple) noisy channels is not valid anymore. However, the principle can be retrieved if we consider more complicated types of channels, that in Information Theory are known as channels with memory and feedback. We show that there is a complete correspondence between interactive systems and such kind of channels. Furthermore, we show that the capacity of the channels associated to such systems is a continuous function of the Kantorovich metric.
paper1.pdf (689.4 Ko) Télécharger le fichier
inria-00479672 , version 1 (01-05-2010)
inria-00479672 , version 2 (19-12-2010)
inria-00479672 , version 3 (01-11-2011)
  • HAL Id : inria-00479672 , version 1
Mário S. Alvim, Miguel E. Andrés, Catuscia Palamidessi. Information Flow in Interactive Systems. [Research Report] 2010. ⟨inria-00479672v1⟩
570 Consultations
316 Téléchargements
