Should penalized least squares regression be interpreted as Maximum A Posteriori estimation? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
Penalized least squares regression is often used for signal denoising and inverse problems, and is commonly interpreted in a Bayesian framework as a Maximum A Posteriori (MAP) estimator, the penalty function being the negative logarithm of the prior. For example, the widely used quadratic program (with an $\ell^1$ penalty) associated to the LASSO / Basis Pursuit Denoising is very often considered as MAP estimation under a Laplacian prior in the context of additive white Gaussian noise (AWGN) reduction. This paper highlights the fact that, while this is {\em one} possible Bayesian interpretation, there can be other equally acceptable Bayesian interpretations. Therefore, solving a penalized least squares regression problem with penalty $\phi(x)$ need not be interpreted as assuming a prior $C\cdot \exp(-\phi(x))$ and using the MAP estimator. In particular, it is shown that for {\em any} prior $P_X$, the minimum mean square error (MMSE) estimator is the solution of a penalized least square problem with some penalty $\phi(x)$, which can be interpreted as the MAP estimator with the prior $C \cdot \exp(-\phi(x))$. Vice-versa, for {\em certain} penalties $\phi(x)$, the solution of the penalized least squares problem is indeed the MMSE estimator, with a certain prior $P_X$. In general $dP_X(x) \neq C \cdot \exp(-\phi(x))dx$.
MAPvsOptim-revision-HAL.pdf (216.16 Ko) Télécharger le fichier
inria-00486840 , version 1 (26-05-2010)
inria-00486840 , version 2 (01-12-2010)
inria-00486840 , version 3 (13-12-2010)
inria-00486840 , version 4 (11-03-2011)
  • HAL Id : inria-00486840 , version 2
Rémi Gribonval. Should penalized least squares regression be interpreted as Maximum A Posteriori estimation?. 2010. ⟨inria-00486840v2⟩
670 Consultations
2333 Téléchargements
