MANET Network Management and Performance Monitoring for NHDP and OLSRv2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Mobile Ad Hoc NETworks (MANETs) are generally thought of as infrastructureless and largely ``un-managed'' network deployments, capable of accommodating highly dynamic network topologies. Yet, while the network infrastructure may be ``un-managed'', monitoring the network performance and setting configuration parameters once deployed, remains important in order to ensure proper ``tuning'' and maintenance of a MANET. This memorandum describes a management framework for the MANET routing protocol OLSRv2, and its constituent protocol NHDP. It does so by presenting considerations for ``what to monitor and manage'' in an OLSRv2 network, and how. The approach developed is based on the Simple Network Management Protocol (SNMP), and thus this paper details the various Management Information Bases (MIBs) for router status monitoring and control -- as well as a novel approach to history-based performance monitoring. While SNMP may not be optimally designed for MANETs, it is chosen due to it being the predominant protocol for IP network management -- and thus, efforts are made in this paper to ``adapt'' the management tools within the SNMP framework for reasonable behavior also in a MANET environment.
RR-7311.pdf (273.36 Ko) Télécharger le fichier
inria-00490958 , version 1 (10-06-2010)
  • HAL Id : inria-00490958 , version 1
Ulrich Herberg, Thomas Heide Clausen, Cole Robert. MANET Network Management and Performance Monitoring for NHDP and OLSRv2. [Research Report] RR-7311, INRIA. 2010. ⟨inria-00490958⟩
206 Consultations
193 Téléchargements
