Achieving Power-Efficiency in Clusters without Distributed File System Complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hrishikesh Amur
  • Fonction : Auteur
  • PersonId : 872154
Karsten Schwan
  • Fonction : Auteur
  • PersonId : 872155
Power-efficient operation is a desirable property, particularly for large clusters housed in datacenters. Recent work has advocated turning off entire nodes to achieve power-proportionality, but this leads to problems with availability and fault tolerance because of the resulting limits imposed on the replication strategies used by the distributed file systems (DFS) employed in these environments, with counter-measures adding substantial complexity to DFS designs. To achieve power- efficiency for a cluster without impacting data availability and recovery from failures and maintain simplicity in DFS design, our solution exploits cluster nodes that have the ability to operate in at least two extreme system- level power states, characterized by minimum vs. maximum power consumption and performance. The paper describes a cluster built with power-efficient node prototypes and presents experimental evaluations to demonstrate power-efficiency.
WEED-amur.pdf (276.39 Ko) Télécharger le fichier
inria-00492835 , version 1 (17-06-2010)
  • HAL Id : inria-00492835 , version 1
Hrishikesh Amur, Karsten Schwan. Achieving Power-Efficiency in Clusters without Distributed File System Complexity. WEED 2010 - Workshop on Energy-Efficient Design, Jun 2010, Saint Malo, France. ⟨inria-00492835⟩
Collections
WEED2010 ISCA2010
57 Consultations
209 Téléchargements
