Modeling and Instrumentation of Memory Hierarchies using Functional Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a methodology for the modeling, instrumentation and design space exploration with prototyping of complex designs exhibiting difficult to anticipate performance caveats. It relies on monadic functional programming as a design specification means. Its advantages lie in its model-of-computation (MoC) mixing capabilities, its suitability for both human-assisted and automatic design space exploration, as well as its relative ease of use compared to other functional approaches. We show those aspects on a case study involving memory fetches from a set of tomographic backprojection coprocessors working in parallel.
WARP2010-toczek-gipsa.pdf (144.3 Ko) Télécharger le fichier
inria-00494114 , version 1 (22-06-2010)
  • HAL Id : inria-00494114 , version 1
Tomasz Toczek, Dominique Houzet, Stéphane Mancini. Modeling and Instrumentation of Memory Hierarchies using Functional Programming. WARP - 5th Annual Workshop on Architectural Research Prototyping, Jun 2010, Saint Malo, France. ⟨inria-00494114⟩
188 Consultations
71 Téléchargements
